10-14-2020, 12:06 PM
Rob's 1988 Baltic Blue & Tan Grand Wagoneer Restoration
Background:
I bought the old girl in mid-November of 2019 as a garage project, mostly to keep myself busy over the last winter, and as it turned out, during the ridiculous China virus lockdown scare.
I found it on FB Marketplace, listed by an older woman and her son thru her deceased husband's account. She wanted $2k, but based on pics and videos I told her I'd drive out from Boise with a trailer to her place in Vancouver, WA to inspect it and go from there.
What I saw in person was much worse than I thought I'd find, as it had a hard life, didn't run, and had a lot of interior floor pan rust, non-functioning electrics, and a lot of missing interior bits. We agreed on $1,200, poured gas down the carb, and gunned it onto the trailer before it died.
Apparently it started life in Berkeley, CA, then moved to Arkansas at some point, where I figure it was used as a hunting rig or something.
I'm still plugging away between work, health issues, and just plain old parts scrounging. Anyway, I'll post occasional pics as I continue piecing things together. Enjoy!
10-14-2020, 12:10 PM
10-4 we look forward to the build.
dave in NC
10-14-2020, 12:14 PM
Here she is on the trailer.
Note the badly biffed, and previously replaced, left front fender, the damaged driver side of the grill, and the dented front bumper.
They graciously swapped out the wheels I didn't like and fitted the older GW wheels (with dry-rotted tires).
IMG_20191123_171110 by Robert Stone, on Flickr
10-14-2020, 12:15 PM
dave in NC
Thanks, Dave. All the parts you sent me will be in these pics!
Here's a good look at my starting point. Incorrect earlier model-year door panels, destroyed seat upholstery, earlier-model, and broken, driver side seat without headrest, beat up dash, missing gear shift knob, door lock knobs, missing tailgate motor, mold, etc:
67503008_2330705303870846_7668228086223077376_n by Robert Stone, on Flickr
Skulls for gear shifter and door locks. Wrong driver seat (no headrest), broken center arm rest, non-functional dash lights, etc.
67507003_726449021129239_6772135034527678464_n by Robert Stone, on Flickr
No right rear window motor and earlier model year door panel. Window was held 'mostly up' by a piece of wood in the door, which allowed a lot of moisture in over however long it was like that.
74584869_2365235687123201_6550784592029155328_n by Robert Stone, on Flickr
Rear tailgate glass was held up by a strap, as the motor didn't exist. Tailgate had also been hit so rear bumper is slightly bent, and tailgate sheet metal was dented and bottom seam had popped. Scored a good assembly from a part-out a month after I bought the waggy.
65781697_342789046398686_4322004892517400576_n by Robert Stone, on Flickr
10-14-2020, 12:35 PM
Taking stock of everything once I got it into the garage. Had a ton of surface rust inside, mold, couple of rust-thru pinholes, and just general corrosion on everything. Both front and rear headliners were missing, figured they succumbed to the elements years ago.
Figured it best to start at the top where water usually gets in, so removed the roof rack, rails, and optional ASC sunroof.
IMG_20191125_183150 by Robert Stone, on Flickr
The optional sunroof. Pain to remove, found some broken bits, but want to keep it. Gunk on bottom of sunroof assembly is spray adhesive, not rust:
IMG_20191125_191004 by Robert Stone, on Flickr
Some surface corrosion here and there, but otherwise in good shape.
IMG_20191125_190957 by Robert Stone, on Flickr
10-14-2020, 12:40 PM
Cargo area had no carpet, no cargo rails, or fiberboard rib underlay, and a ton of screw holes that definitely were not from the factory cargo rails. Best guess is someone made some homemade tie-down points.
IMG_20191127_094640 by Robert Stone, on Flickr
Started with yanking the seats out:
IMG_20191127_092928 by Robert Stone, on Flickr
Look, a clean spot!
IMG_20191126_151228 by Robert Stone, on Flickr
Carpet kit was trash so just yanked it and tossed it in the trash:
IMG_20191127_094655 by Robert Stone, on Flickr
Good look at all the surface rust:
IMG_20191126_171009 by Robert Stone, on Flickr
10-14-2020, 12:45 PM
Got tired of constantly pumping up the dry-rotted tires, so scored some used ones on FB for $150. Gave the seller his rims back after removing the good tires from them.
IMG_20191202_182855 by Robert Stone, on Flickr
Good tires on the left, old crud on the right still mounted:
IMG_20191203_200437 by Robert Stone, on Flickr
Had my wheels and center caps powder coated in semi-gloss black for $210. Too much surface corrosion to want to attempt a repaint, plus this looks meaner:
IMG_20191216_165336 by Robert Stone, on Flickr
Finished product after mounting the tires:
IMG_20191217_190418 by Robert Stone, on Flickr
10-14-2020, 02:17 PM
A couple more examples of how beat up the old girl was. Driver door panel was water corroded and eaten away at front bottom:
IMG_20191214_110147 by Robert Stone, on Flickr
Front passenger door panel was better, but missing trim and was pretty molded:
IMG_20191214_110417 by Robert Stone, on Flickr
Most of the cargo area stuff was missing. Scored most of it from ebay, and bought new full ACC carpet kit.
65363237_2357306894590790_5543873434112491520_n by Robert Stone, on Flickr
10-14-2020, 02:24 PM
it sure is fun to dig into a new project,...
taking all the worn stuff out,...
discovering this and that,.....
now your mind will be constantly thinking of
what you want to do next, buy next,...etc....
Man, those RIMS LOOK GREAT,.....sounds like a deal for the powder coating.
floor looks solid,.....
dave in NC
10-14-2020, 03:49 PM
dave in NC
No doubt, Dave, always fun to figure out the next steps. 10% military discount for the wheels and center caps. I'll use them again if I have anything else to coat.
Floors had some cratering, but only a couple pinholes thru the metal that needed sanded and welded up. I'll include some pics of the work done there later.
10-14-2020, 08:09 PM
glad the old wagoneer is getting attention,...
it was needing some TLC,....
like rescuing an abandoned dog...
I love doing the floors, its one thing I can do,....
you may have said ,.. but what coating are you planning to use on the floor ?
dave in NC
10-15-2020, 08:58 AM
dave in NC
I used 2 types of POR-15 after cleaning and using their metal prep. The passenger area of the floor pan got 1 pint of the silver version with the metal filler that settles into the craters, then I followed up with a quart of the semi-gloss black, which I also used in the rust-free cargo area. I was VERY impressed with this stuff. Filled in the craters nicely and looks like it will last longer than the rest of the Jeep.
Buddy of mine welded in the million different holes in the cargo area, then I sanded and did the POR-15:
IMG_20200201_102840 by Robert Stone, on Flickr
Floor welds sanded down, metal prepped, and first coat of black POR-15:
IMG_20200201_215703 by Robert Stone, on Flickr
Silver coating with the metal filler in front, where the rust did a crater number on the pan. This is just starting to settle:
IMG_20200220_181833 by Robert Stone, on Flickr
The finished product looks great!
IMG_20200221_163234 by Robert Stone, on Flickr
10-15-2020, 10:37 AM
The factory adhesive on the roof support rails had failed so I removed them and began the long process of sanding down the rust and removing the factory adhesive and cleaning up roof rack and rail holes:
IMG_20200105_213638 by Robert Stone, on Flickr
IMG_20200108_214041 by Robert Stone, on Flickr
IMG_20200118_155925 by Robert Stone, on Flickr
I sanded all the rails, then used 3M 08115 Panel Adhesive and Manual Cartridge Applicator 08571 from Amazon to get the rails reattached:
IMG_20200118_164538 by Robert Stone, on Flickr
Then I used boards to wedge the rails back up after using the bolt holes to line them up:
IMG_20200118_172624 by Robert Stone, on Flickr
Then I used a space heater and blankets to heat the adhesive to over 100* to set it completely so the rails don't break loose again:
IMG_20200118_172904 by Robert Stone, on Flickr
10-15-2020, 11:59 AM
Once I got the rails back on and dried I primered the roof for rust protection:
IMG_20200122_190112 by Robert Stone, on Flickr
Rolled some more Kilmat onto the roof to keep things insulated and quiet:
IMG_20200124_204537 by Robert Stone, on Flickr
Did some detail work and painted the rear speaker frames:
IMG_20200126_164618 by Robert Stone, on Flickr
10-15-2020, 01:31 PM
Great progress .. keep at it. All the small steps add up over time.
Cool project.
10-15-2020, 01:43 PM
WOW
love POR-15
a NICE, NEAT PRECISE job on everything
love the photos
you are making a chunk of coal into a diamond.
dave in NC
10-15-2020, 01:46 PM
hey man
while you have been in the interior working
have you noticed the
threaded holes further back in roof
near where the back of the back seat would be
but up in roof cavity,....
I used those holes to install 3rd row belts
although they will prob never be used in my lifetime....
I think I remember reading the threaded holes were for a tire carrier ?
can't remember....
10-15-2020, 02:30 PM
Used new grommet and screw sets to reinstall the roof rack and slats, and followed up with a slathering of flexible gasket maker for water tight integrity:
IMG_20200323_103209 by Robert Stone, on Flickr
Roof rack grommets nicely slopped to avoid water intrusion.
IMG_20200323_103155 by Robert Stone, on Flickr
Thread Tools |
Display Modes |
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Baltic Blue touch up paint? |
Mavawreck |
General FSJ Discussion |
5 |
05-30-2011 08:54 AM |
