I have a whurring / grinding noise when I depress the clutch which will change with RPM changes. It is more pronounced when it is shifted into a gear, and will get worse when the transmission is at operating temp. I think it has to be either the pilot bushing, throwout bearing or the input shaft bearing as those are the only components moving when the clutch is depressed.
Sounds simple right? let me give you some more background. I have owned the J-10 since 1985. 360, T-18 with the long input shaft, Dana 20 xfer case. After the first engine rebuild in 1985, I went thru about 5 throwout bearings, but the pilot bushing would be messed up as well. We ended up replacing all the 3 parts and this lasted 20 years. This year I went and did another complete engine and transmission rebuild, when I pulled the old transmission the input shaft was so loose, that it had eaten up the input shaft bearing retainer (that the throwout bearing rides on). I replaced the transmission with a re-built transmission from the guys at Novak. I went with new everything, flywheel, centerforce clutch, bearings, bushing. I even measured the runout of the bellhouse, which appeared to be within specs. Now, 3000 or so miles into the rebuild, I have the noise again. Am I missing something?????
Any help would be appreciated.
