Putting in Bj's 2.5" Lift. Need to also replace my shackle bushings (Mine are in rough shape, as were my stock springs). I have a press 20 ton press but it seems like the exterior bushing sleeve is so thin it would be hard to press out. Also heard of people burning out the rubber then using a saw to cut through the thin wall allowing you to bend the sleeve out. Is there an easy way to press these out on the press? What's the easiest way to do this?
Thanks!
Thanks!
