Wow! It's hard to imagine 18 full sized jeeps in one parking lot. Who's going to supply all that floor dry?
AZFSJC Valley Area Meet & Greet -- March 3, 2007
Mike,
When you say output gear are you referring to the front output collar that the front output shafts splines into, or are you referring to the engaging collar that the vacuum diaphram connects to? I will look at what I've got and bring along the part time pieces I have. If your problem is what I think it is, the vacuum diaphram is or has failed and allowing the shifting collar to walk back and forth while it was engaged in 4wheel drive. Due to the fact that there is such little tooth engagement and only I think 7 or 8 teeth, they strip pretty easy if not fully engaged.
See you all there. Are we going to have enough parking? So the RTI ramp is out somewhere else Tom?
Kevin.\'78 Cherokee Chief - 360/TH400/QT Front high pinion 44/ARB/4.10-1, Rear 44/ARB/4.10-1, SOA w/Alcan front springs, Alcan full-leaf (w/shackle eye flipped) rears, custom bumpers, Multi-mount Warn XD9000i, more money into her than I want to admit. Dad purhcased new, still have window sticker. 310,000 miles.
Originally posted by gwinnNo......... no.......... please no Babs!2000 Infinity QX4, 3.3L, MPFI, 4 speed auto, 2 speed Nissan tcase, Unibody, IFS front, 4 link rear solid axle with 255-70/16s
Babs vs Rstep
Originally posted by tadsalGees...Fine...I'll bring Rstep
Originally posted by 78 Arizona Chief... See you all there. Are we going to have enough parking? So the RTI ramp is out somewhere else Tom?Last edited by gwinn; 03-01-2007, 06:53 PM.1983 Cherokee Laredo "Gus"
Yep, I am waiting on this also. Save me some room with for my camper also.
Kevin,
I'm not sure exaclty where the problem is I know that it would engange when I put the thing together a few weeks ago and that it worked for about 6 miles before it stopped engaging. (I was preforming a no no, running front drive only with the rear drive shaft disconected do to a rear pinion being broken. Just to get the vehicle to work so I could put a new ring and pinon in without towing it there.) It would engage for a short time in reverse only after forward stopped working. now I have no engagement at all. It did make a gear tooth not engaging or striping noise at the time of failer. I have not had the time to tear the case apart to see what the problem is yet.
Mike A and Flying (er gounded) LadyMike A and Flying Lady
Its a Full Size Thing you wouldn't understand.
79 j-10: 360 th400 dana 44 w/lockrights rear. 4.27 gears, Rino grill 6" KC's in 5 3/4 buckets, custome rings for both 7 and 5 3/4 lights, custom front bumper with warn classic winch, 1" extended shackles front, 6" lift kit, 35 12.5 15 tires, edlebrock intank and 4bl carb.
I'll try to get a list of stuff together that needs to go away (everything from axles to fenders, probably the SOA'd J2000). My rig being chopped is not a great transport rig and my Nissan barely holds anything so it will have to be picked up, which will make it cheap.2000 Infinity QX4, 3.3L, MPFI, 4 speed auto, 2 speed Nissan tcase, Unibody, IFS front, 4 link rear solid axle with 255-70/16s
On that parts list
Do you have an ashtray for my '83? I'm not sure which years had the same set up, but I think my old '70s Wags were the same with the ashtray being left of the radio at top center dash. Clock is the on right, but if they ever made an ashtray for that spot too I'd swap one in. I don't smoke but I have a lot more use for a small junk collecting bin than a clock.1983 Cherokee Laredo "Gus"
No ashtray here, sorry.2000 Infinity QX4, 3.3L, MPFI, 4 speed auto, 2 speed Nissan tcase, Unibody, IFS front, 4 link rear solid axle with 255-70/16s
Making some sandwich's and then heading out to top the tank.See everyone in a few hours.77 Cherokee 401/400 trans,Holley on edelbrock performer,PT 1339
d44s,detriot rear ,diff guards front and rear
Fabbed front and rear bumpers,Tire carrier
33"BFG KM2's on black spokes
Tadrack
Interior upgraded,Durango console, custom gauge panel,bucket seats
Soa,with 1" shackle up front
Hood vents
