Old 10-28-2020, 08:19 AM
Late Model Hi-Lo 4WD Handle Pics
I've looked everywhere but can't find any good close-ups of the immediate area around the Hi Lo 4WD handle where it goes into the tranny tunnel.
I'm installing my new ACC carpet kit and I'm not sure what was exposed around that area, and what the carpet actually covered. Was the handle base visible over the carpet, or does the carpet cover everything but the handle, etc?
I'm trying to get as close to original look as possible so any pics you guys could post of original look would be greatly appreciated.
Rob
Old 10-28-2020, 08:27 AM
Brynjminjones's Avatar
I'm working at the moment, but I can get some photos of my 1991 with original carpet in a couple of hours
1991 Grand Wagoneer - Hunter Green. All stock. Rebuilt 360 with Melling MTA-1 cam.
1998 Cherokee (XJ) 4.0
1997 Grand Cherokee (ZJ) 4.0
1974 Ford F100 390
Old 10-28-2020, 08:42 AM
I just found time to get some pics now, hopefully these will help.
You can see that the whole shaft and handle is exposed, but the point where it comes through the floor is hidden by the seat base.
Mine is 100% original, except for the fire extinguisher I'm holding out of the way!
Wagoneer Transfer Case Lever by Brynjaminjones, on Flickr
Here's the view from above:
And a better view of where it hides behind the seat rail:
1974 Ford F100 390
Old 10-28-2020, 10:48 AM
Awesome, so the base is completely covered, just the handle is coming thru the carpet. That answers that! Thanks again!!!
Quick question "while I have you here", are you supposed to be able to move that lever while the vehicle is in park with engine off. If not, when are you supposed to be able to move it? Mine won't budge with the car in Park, or any other gear with the engine off.
Rob
Old 10-28-2020, 12:28 PM
No problem, happy to help!
The lever should only move from 4hi to 4lo when it's in 4wd, done via the switch on the bottom of the dash.
Once in 4hi, I find sometimes the lever will work when stationary, but sometimes it won't and I need the Wagoneer to roll slightly to get it to budge.
1974 Ford F100 390
Old 10-28-2020, 01:01 PM
Excellent. Since I've had it started just long enough to roll onto the car trailer, and a few seconds a few months back after the carb rebuild, I haven't had a chance to see if anything actually works.
I know the 4WD control lever won't do anything since one of the hardline vacuum hoses that control everything is broken just past the firewall in the engine compartment. That's another thing on the long list of mechanical 'to be fixed' items.
Old 10-29-2020, 11:11 AM
that carpet sure looks great b jones
looks like the original deep pile too.....
Old 10-30-2020, 04:52 AM
Thanks!
I think the flash makes it looks better than it is, but I'm still very happy with how well it has lasted.
Unfortunately that means I have to be quite careful with it, as I don't want to ruin it!
1974 Ford F100 390
late model wipers Jeep Craze General FSJ Tech 5 12-04-2013 12:51 PM
Has anyone tried using a roof rack or mirrors from a late model SUV on their FSJ? mdcptman General FSJ Discussion 9 09-14-2013 08:12 AM
Late model Grand Wagoneer spotted. austinaubinoe General FSJ Discussion 11 08-10-2012 06:43 PM
late model "bolt in"? fsj1978 General FSJ Tech 22 09-19-2008 09:24 PM
dual battery late model G-wag? wagonman83 General FSJ Tech 4 09-22-2004 02:11 AM
