Old 10-01-2017, 06:26 PM
J20 project's Avatar
J20 project J20 project is offline
First choice.......14 bolt rear, D60 front.....
Second choice...Go find a rear D60 from a J20..move the perches...done...Take the front 44hd and swap it....or just swap the front hubs. or get 10 bolt chevy fronts like me...
IF you plan for spring over...okay..but I would strongly suggest you roll the front axle if low pinion. If high pinion....cool. But w/ low pinion...caster is screwed if you roll it to lessen dshaft angles. Probbly plan for high steer just the same.
J20
BP Drivetrain...........
775-537-7918
Old 10-06-2017, 03:36 PM
lycanthrope's Avatar
lycanthrope lycanthrope is offline
A little far for you, Corey, but there is a ford high pinion 44 in a '77 f250 at the yard in sun valley, ca.
In years past, I would be all over it. This weekend I am here for a wedding.
tommy
'83 j10 pioneer 258/t5/208...gone
'81 j10 sportside 258/t176/208
'76 j10 shortbed 360/th400/QT
'81 j10 sportside 258/tf999/208
'74 j10 shortbed ...gone
Old 10-07-2017, 09:24 AM
Which yard?
Old 10-09-2017, 02:25 PM
Pick a part sun valley.
You can see it online.
I figure that I will regret leaving it behind, in the future. I spent a week stripping the j20 in the yard in May, I think that I have enough axles. High pinion is rare, though.......
I can send you a pic if you want.
tommy
Old 11-21-2017, 08:47 AM
coreyw454 coreyw454 is offline
what about this guy?
https://monterey.craigslist.org/pts/...395210345.html
1985 Grand Wagoneer (project)
1989 Grand Wagoneer (parts for 85/off-road only use)
