Old 02-05-2019, 10:06 PM
J71Truckster's Avatar
J71Truckster J71Truckster is offline
New here 71 J4000
Have a awesome old J4000 I'm slowing beginning to build 360 th400 Dana 20 d44 d60 semi float rear. Super clean minus needing floor pans. Got a question about disc brake conversion for the front closed knuckle a axle like donor parts or is it better to just go with a bj off road kit? Thanks
Old 02-09-2019, 11:59 AM
Herk's Avatar
Herk Herk is offline
Welcome. I converted my 71 to front disks before the "kits" were widely available in the 90's. Even then the only junkyard parts I used were the backing plates. I used my original hubs but needed to face the back side of the wheel flange, press in new studs, etc... If I had to do it over today, I would probably order a kit.
If the 12" drums you take off are in even close to usable condition don't scrap them, they're currently hard to find.
Old 02-09-2019, 08:50 PM
Thanks herk like the idea of an all new parts kit just didn't know if maybe could create my own with gm front backing plates and calipers and use Ford hub and rotor when I get it done I'll post some pics
Old 02-16-2019, 10:58 AM
DarkMonohue's Avatar
Shakes hands with danger
Welcome! It's always good to see more pickups around here to shore up the numbers a little.
Old 02-17-2019, 03:57 PM
iapexl8r's Avatar
iapexl8r iapexl8r is offline
Heyj71 welcome aboard. .... I like it. trucks rock
1976 Cherokee chief
1970 AMC rebel THE MACHINE
1969 AMX
1965 mustang fastback
1972 international travelette
Yes I have a problem that’s why Iam here
Old 02-25-2019, 09:46 AM
Yep! Browed trucks are even more Rock'ish! you have a cool truck to start with and you can nuts on these. Good times!
J4000 GVRW versions..?? RuidosoKid General FSJ Discussion 9 07-22-2017 03:29 PM
72 J4000 Tie rod ends AUSTJ4000 General FSJ Discussion 4 10-16-2015 07:11 PM
will j4000 styleside bed fit j3000 truck fully standard jeep General FSJ Discussion 2 04-23-2015 07:37 PM
J4000 - BJ's Springs tvorhies General FSJ Discussion 7 12-12-2010 10:01 PM
J4000 Question VAJ4000 General FSJ Discussion 27 04-01-2008 09:29 AM
