Old 08-26-2009, 11:08 PM
Blake Blake is offline
1310 - 1350 u-joint part number
I just swapped in the D60/14 bolt into my '78 J10.
I *believe* that I need a 1310 - 1350 combo u-joint so I can connect my stock rear drive shaft to my 14bolt. Anyone know what the part number is so I can call the part store and tell them I need X part number?
thanks!
Old 08-27-2009, 06:13 AM
rustywagoneers_com's Avatar
rustywagoneers_com rustywagoneers_com is offline
I believe you are looking for a 348 (precision number).
Will check.
There is no way to rule innocent men.
The only power government has is the power to crack down on criminals.
Well, when there aren't enough criminals, one makes them.
One declares so many things to be a crime that it becomes impossible for men to live without breaking laws.
Old 08-27-2009, 06:15 AM
http://www.summitracing.com/parts/PCN-348/
check it out.
Do you have an 'Oreilly's'? My somewhat local one carries that PN.
Old 08-27-2009, 06:18 AM
fullsizejohn's Avatar
fullsizejohn fullsizejohn is offline
spicer 5-460x
http://eastcoastgearsupply.com/i-135...n-u-joint.html
this guys kinda high...i can get them local for about $25
jw
'77 cj-5,
'78 j-10,(not running)
'79 J-10 360ci,t400,D300, SOA-D60w/ARB, 14B w/Detroit,4:56s, 37" TRXUS
'06 Ford F250 super duty crew cab
Old 08-27-2009, 07:52 AM
thanks guys
I also found napa part number PUJ 348
http://www.napaonline.com/NOLPPSE/%2...348_0214930152
Old 08-27-2009, 08:32 AM
Question for the folks running these joints:
How are they working out for you?
Vibrations?
Anything weird about them?
TIA
Old 08-27-2009, 08:48 AM
I wound up getting a 1310 D60 yoke for my front, and did not need the 1350/1310 conversion joint.
However, I am running a 1330 (ford) to 1350 conversion joint in my rear shaft and it is no problem.
The 1330 part will fail first, for sure. But it is no weaker than than the plain 1330 at the t-case end of the rear shaft. And no more likely to produce a vibration than my home-shortened rear driveshaft.
Old 08-27-2009, 09:05 AM
Chevelleguy's Avatar
I used to run a conversion joint on my drag car with a 9" rear end. Never had a problem. Snapped an axle once, blew the carrier caps out once, never broke a u-joint. 6.399 @ 106mph in the 1/8th with a SBC Chevette (yes I said Chevette) on 275hp NOS. It would drag the back bumper for 150ft.
Old 08-27-2009, 10:13 AM
TPICherokee's Avatar
Shouldn't your handle be Chevetteguy?
Old 08-27-2009, 04:15 PM
Vibrations?
TIA
Honestly, i havent run mine enough to have an opinion on it. Seems ok
'77 cj-5,
Old 08-27-2009, 04:22 PM
El Jefe's Avatar
El Jefe El Jefe is offline
I put one in mine. didn't drive it at all. changed my mind and had Tom Woods change my driveshaft to the 1350
Alex
76 Cherokee Chief
350/th400/d20
d44/14b
4" lift, 35 inch retreads
Old 08-27-2009, 05:00 PM
fubar's Avatar
fubar fubar is offline
ive killed 2 of those 1310/1350 conversion joints tho ive got a built motor an 40inch tires
67 wagoneer
84 grand wagoneer
76 cherokee
67 gladiator
Old 08-27-2009, 08:15 PM
jtr's Avatar
jtr jtr is offline
I wear out more u-joints than break them. Seen more axle breakage and driveline destruction before u-joints.
FYI, I run 1330s and a 1330 to 1350 conversion in the rear.
In truck pulls I have seen waay more u-joint failures but that is usually caused by weight transfer on the sled and a "excited" driver. Read.... extreme axle hop.
Jeep is gone ~~ Ranger cab truck in the works
393W/C6/203-205, HP60, 14B, 12 bolt H1s, 40" Pitbull Rockers, full hydro, 4 link rear
Build = http://www.pirate4x4.com/forum/showthread.php?t=973973
Old 08-27-2009, 09:14 PM
napa part number PUJ 348 worked!
I got everything all buttoned up except the axle shafts.
Should take it for a test run soon!
