  #221
Old 02-27-2008, 07:29 PM
McRoth's Avatar
McRoth McRoth is offline
Yes, BUT you have to swap the output shaft of the Jeep 727 with the Dodge 727 shaft. I learned this the hard way when I found that the Jeep adapter is about 2" shorter than the Dodge!! Luckily I needed to get the trans rebuilt anyhow, so they just did it while it was apart.
Mike
78 WT Cherokee Chief Levis Edition, Rebuilt 401, DUI, Hickey Winch, Headman Headers, Dual 2 1/2" Exhaust.
88 Grand Wagoneer - SOA, D44HD & D60, 203-205 Doubler, Rear Disk Brakes, 36" H1 Double Beadlocks
02 VW Jetta TDI - DD
82 Mercedes 300TD
1953 Dodge B4-F 1 1/2 ton stake bed - Restoration Project
Old 02-27-2008, 08:35 PM
shadowjeep's Avatar
when you say the jeep adapter you just mean the rear output of the transmission right? not an actual adapter added to the trans.
Rick C.
www.kymc.org
shadowjeep
2003 Chevy Silverado
Old 02-27-2008, 08:46 PM
McRoth's Avatar
The adapter between the trans & transfer case.
Mike
82 Mercedes 300TD
Old 03-03-2008, 04:12 PM
shadowjeep's Avatar
mcroth, you got any pics of the new setup? i would like to see any differences there might be. i do have a tranny in need of rebuilding, ill have to find a dodge tranny to swap outputs.
Rick C.
www.kymc.org
shadowjeep
Old 03-06-2008, 10:30 AM
McRoth's Avatar
I'll try to get them for you tonight.
Mike
82 Mercedes 300TD
Old 03-06-2008, 11:52 AM
shadowjeep's Avatar
cool, sounds good. i have been wanting to rebuild a 727 that i accidently burned up a while back. that will give me a chance to kill two birds with one tranny.
Rick C.
www.kymc.org
shadowjeep
Old 03-06-2008, 06:27 PM
McRoth's Avatar
Here they are. I really need to clean up the output shaft & oil it!
Mike
82 Mercedes 300TD
Old 03-08-2008, 08:32 AM
shadowjeep's Avatar
thanks for the pics, that helps a lot when going to the boneyard to find a tranny. what years should i look for on the dodge tranny?
is the dodge 203 the only one that will bolt up to 727? what about the gm 203? or is that the same thing?
Rick C.
www.kymc.org
shadowjeep
Old 03-09-2008, 10:36 AM
McRoth's Avatar
I believe the mid to late 70's dodge's came with 203's, at least some of them. I got my output shaft from the tranny shop that did my rebuild, you should be able to find one that way too, I'd think. it was on ly $20.
Yes, the dodge is the only one that will work AFIK.
Mike
82 Mercedes 300TD
Old 12-31-2008, 03:54 PM
mark's Avatar
mark mark is offline
is it somehow possible to adapt 2 cases so that i can get a driver side drop?im currently running a t 400 and a 205.just wodering if i could mix things up somehow to get a dr side drop so i can use a hp ford dana 60 with my current chevy setup.
mark<br />76 cherokee chief<br />chevy 502 t-400 np-205<br />dana 60 front corp 14 bolt rear<br />fiberglass fenders and quarters<br />(ABOVE THE LAW)(AND UNDER CONSTRUCTION)<br /> [IMG]<br />[url=http://www.fsjworld.com/mygallery.ten?id=3481[/URL]<br />[/IMG]
Old 12-31-2008, 04:16 PM
Long&Low's Avatar
Long&Low Long&Low is offline
Well, the Ford NP205 is a 32 spline unit if I remember correctly, and it drops down on the driver's side. You'd have to figure how to mate a Ford NP205 to your NP203 of your choosing.
I picked up my adapter from a guy off of Pirate named Dirtybird, his stuff was inexpensive, and he made adapters to fit different 203 range boxes to lots of stuff, even Dana 300's.
Breakfast amounts to one live toad, I choke that mofo down, and I am rest assured that nothing worse will happen to me for the rest of the day.
___________________________
'68 CJ5
'92 YJ
'06 Commander
Old 12-31-2008, 06:32 PM
JeepsAndGuns's Avatar
The ford version has a 31 spline input, and 32 spline outputs. I would call around to the diffrrent doubler kits makers and ask if they make one where you can use a ford 205 with a chevy 203 range box
Old 01-05-2009, 07:57 AM
mark's Avatar
thanks for the info!
Old 02-16-2009, 09:11 AM
noflyzone's Avatar
noflyzone noflyzone is offline
Everytime I read this thread it gets more complicated. I want to do the doubler behind my 727 but it sounds like now I have to swap parts off of a dodge 727 to start with. might as well go Black Box or Klune or just go atlas and be done with it.
Old 02-16-2009, 10:05 AM
orangecherokee's Avatar
if you've got the money I would. doublers are for folks on the cheap.
Old 02-16-2009, 03:14 PM
noflyzone's Avatar
As broke as we are right now everything is just a dream anyway.
Old 01-03-2010, 08:03 AM
Elliott's Avatar
Elliott Elliott is offline
Cowboy Up
NW Fab can match it up for you. Any 203 with any 205 and they probably have other combos.
I finally got mine clocked where I need it. Kind of a bugger to do the clocking when it's installed on a rig but the 3" body lift made things easier. I have it so everything.... everything including the crossmember stuffs up under the frame and I have a cutout to drop the front driveline down through the crossmember.
I don't know about this being cheap, cheaper probably. Where is the challenge of just buying something in a box that takes six bolts to attach? Besides, with the 203/205 you have two places to run a PTO off of.
Old 03-21-2010, 07:52 AM
I'll be running a Dodge 203 and a Ford 205 in Crom soon. I got the adaptor from http://www.sumnermachine.com John and his wife were really nice and he started on it as soon as I called, so that when I made the second payment to him he had it boxed and ready to ship!
Old 08-16-2010, 09:35 PM
Elliott's Avatar
Cowboy Up
Glad he's back in gear...
I've got a TH400/203 and a '90 NP205 listed in the forsale section if anyone is interested, also up on ebay. I can work it to piecemeal it depending on what someone might need.
Old 09-11-2010, 06:47 PM
Elliott's Avatar
Cowboy Up
I've updated all the dead pic links in my posts. Now, who's put a GM NV4500 to a 203 range box?
I've mated one to a GM six bolt NP205 with some clearancing and a short input (as posted in my dually thread at: http://www.ifsja.org/forums/vb/showthread.php?t=83955 ) so wouldn't this work the same as how I studded the GM NP203 case to match up with the Ford NP435 I did earlier?
