I own a two post lift and would like to lift the body off the frame on my 84 GW.
Is there any guidelines to go by? I want to ensure I remove what is needed but to not go overboard as well. The body can stay on the lift while I'm reconditioning the motor and frame so it should be a fairly simple task.. correct?
I searched but most body lifting was coming from the top or inside using a motor hoist to some extent.
Here is what I'm guessing:
- AC connections removed
- wiring harness removed from firewall.. what else here?
- body mounts unbolted (how many)?
- interior out... do seats bolt to frame and need to come out or no?
- gas tank down spout inside rear quarter panel
- bumpers.. anything on these or will these stay on frame?
- front fenders and clip, do these need to come off as well?
Thanks for any help!
Bryan
Bryan
