  #41
Old 12-28-2018, 03:45 PM
BA_051 BA_051 is offline
And finally, I am restoring the dash pad. It was in pretty good shape when I received it, but It was in need of some repair. So I removed all the old vinyl, and cut the pad into 4 pieces because it shrunk nearly 3/4" with age. I used original gorilla glue to expand and fill the 1/4" gap and it did really really well. I used my dremel and sanded it down then covered it with 1/8" high density closed cell foam. I have to cover it with vinyl still. But here it is right now.
(12v swap in progress) 1974 Jeep J20, gladiator grill, 12v p7100 cummins, Modified He351, 4" strait piped, NV4500/Ford NP205, D60HP, 14b, 4.56's, 12" lift, 37x12.50x16.5's
Old 01-10-2019, 09:44 PM
Well Some of you may have noticed my post in the wanted section for an 86+ dash pad... Between the cats clawing at it (I dont know why they are infatuated with clawing foam, any foam), and my 3 and 5 year old, it ended up in a lot of pieces...
SO for now I am without a dash pad.
On the up side, I have my center seat, and drivers seat bolted back in and I reworked all the dash wiring. It is no longer a rats nest. Little more trimming on the carpet on the passenger side and it will be complete.
Then to make a new heater box and reinstall the factory heater under the dash and plumb the turbo to the intake and make an air box.
I will keep everyone updated with pics as I get them done.
Steering colum swap question derf General FSJ Tech 15 02-04-2010 09:01 AM
Muncie SM465, GM 10 bolt 8.5, GM 14 bolt 10.5 and NP 208 swap Chris Barry General FSJ Tech 9 02-26-2007 03:25 PM
