Here is the situation. 86 GW, just rebuilt the carb, new fuel pump, new fuel filter, new gas lines from carb to pump. No leaks I can find from the fuel pump to the tank. It runs great. Leave it sit for a day and you have to crank for a while to get the gas back up to the carb. Fuel gage swings when your on the road. Registers correct when still for a while. Question is...is there a check valve in the fuel float assembly or am I missing something else.
Check valve in fuel line somewhere?
Your fuel pump should be the only thing between the carb and tank to block backflow.
I had the same exact problem, do you have an Edelbrock carb? I don't like them anyway so I put a Holley on it and problem solved.
I really don't know how the Edelbrock was doing it, it wasn't leaking and it was almost new. I really didn't expect the carb was the problem but it was.
You could have a bad fuel pump. just because parts are new doesn't mean they good anymore with all this Chinese junk.
Common problem with today’s gas. It is blended differently then when carbs. we’re common. It evaporates very easily in a carb which is why it is empty after a day or two. Evaporation doesn’t happen with fuel injection.
One solution is to use an electric pump to prime the carb. before you start the engine.
I did this to one of my cars for a quick startup after sitting. I have a electric fuel pump just outside the tank and a bypass fuel line teed around it with a check valve so the stock mech fuel pump can pull fuel around the electric pump. The electric is only used to prime the carb. Plus it helps with vapor lock issues which I haven’t had yet
And this is for an edelbrock/ carter type carb which seem to be most susceptible to this problem
Mine has always done the same thing. Rebuilt carb with no change. One thing some have flagged as causing this is improper orientation of your fuel filter since it also serves to return excess fuel to the tank. If the return is not orientated at 12:00 the theory is the fuel can drain back from the carb. It never made any difference in my situation. I think it is much more likely to be the filter than a fuel pump. Maybe my filter is too far below the level of the carb and it still allows drain back. I don't know.* 1981 stepside, 360, 727, 208, almost stock daily driver.
It's the gas.
No way for fuel to get past needle & seat.
If it isn't leaking out of power valve, etc.
Been an issue for years w/ carbs and today's "fuel".
Real gas doesn't do it. It's not just a Jeep thing.Tony
Mine did it long before ethanol was added to fuel. That's not to say some other additive doesn't cause it though. If it's not moving past the needle I guess it must evaporate out for some reason with the carb design.* 1981 stepside, 360, 727, 208, almost stock daily driver.
Originally posted by rapomEven the 100% gas sold nowdays is different than the 100% gas of 30 years ago.* 1981 stepside, 360, 727, 208, almost stock daily driver.
Originally posted by Bullfrog...just rebuilt the carb, new fuel pump, new fuel filter, new gas lines from carb to pump. No leaks I can find from the fuel pump to the tank. It runs great. Leave it sit for a day and you have to crank for a while to get the gas back up to the carb. Fuel gage swings when your on the road. Registers correct when still for a while. Question is...is there a check valve in the fuel float assembly or am I missing something else.
a) the bowl in your carb holds probably close to a cup of gas. There is no way that much fuel (good or not) is going to evaporate in a day. If you were evaporating that much fuel that fast, your truck would smell like a rolling gas can. My truck sat on jackstands for 6 weeks without firing then I replaced the fuel filter, and it still fired up fairly quickly when I turned the key. Even if there is no gas in your lines, your truck should fire right up and idle for about 20 seconds with the fuel in the bowl, which should be long enough to get your fuel through the fuel lines to the needle valve. So either it is leaking somewhere you can't see or it's not firing for a different reason than you think.
b) I bet you are losing fuel into your engine as it sits. So when you crank your engine the next day its a little bit flooded. I don't think its really fuel getting through the lines to the carb, I think it's fuel getting into the carb and filling the bowl.
Here's what I would do: let your truck sit for 2 days (so you KNOW it will be hard to start), pull the top of your air filter, spray a quick squirt of starter fluid down the throat, and blip the throttle once from the linkage to verify your choke is closed all the way. try to start it. If it fires right up and dies, your bowl is empty and you have no gas going into the engine and you need to figure out how your bowl is empty in just 2 days. If it fires right up and idles smooth and high, let it idle for about 30 seconds and blip the throttle to ensure the choke opens all the way and it settles into a low idle. If it won't start/fire with the starter fluid, you may need a tune up. if it stumbles at first, then starts to idle high, you may be flooded because fuel is leaking into you engine from the bowl.
Has it run/started correctly since you rebuilt your carb? you may not have the carb/choke adjusted correctly since the rebuild...
The fuel gauge is completely unrelated to your starting issue. I would focus on getting it to start correctly, then move on to the gauge...Chuck McTruck 71 J4000
(Chuck McTruck Build Thread)
00 Baby Cherokee
Did you put the spacer between the carb/intake? I wonder if you are baking some of the fuel out. Also, is your carbon canister hooked up? If not, did you plug the port on the top of the bowl?Chuck McTruck 71 J4000
00 Baby Cherokee
It did this before the carb rebuild. It has new plugs, wires, dist. cap and rotor, new gaskets and isolator under carb and it is torqued to specs. I'm starting to think like Rang a Stang in that the fuel is going from the bowl into the engine. Now, what would cause this, power valve?
