bumper mounts cut off
  • SOLSAKS
    • Jul 25, 2016
    • 1781
    I have 1976 honcho
    it has a wench bumper
    wanted to put a regular FSJ bumper on
    not the 3 piece factory type for 76
    but the later one piece style
    but when I looked at mount area
    it appears the previous owner cut off the portion of the frame that extends beyond spring mounts.... where the 3 hole brackets usually go.
    do you guys think a factory one piece can still be attached ? or am I stuck with the wench bumper ?
    I guess someone with welding and fab experience could still make it work,...
    did not know if anyone else has ran into this.
    I know it would be better with photos
    but I have still not figured that out.
    dave in NC
  • #2
    As far as I know, the pre-1980 frames didn't have the horns off the front, they were flat from the factory. To use a later bumper, you'll need to create those mounts yourself.
    aa
    • SOLSAKS
      • Jul 25, 2016
      • 1781
      was beginning to think there was a difference
      never really liked the 3 piece bumper
      but would use one if I had to.
      thanx for the information
      kinda glad there is a chance nothing has been hacked off !
      dave in NC
      • SJTD
        • Apr 26, 2012
        • 1956
        You shouldn't be bumping wenches with your truck anyway.
        Sic friatur crustulum
        • #5
          I really don't think it'd be that difficult to make brackets to use the later style bumpers. You could probably even grab a piece of "C" channel the right dimensions and use that and the factory holes on the frame.
          aa
          • 80Limited
            • Feb 19, 2015
            • 242
            If it is that pressing I have a junk chassis that I’m going to scrap anyway. It has good bumper mounts that could be cut off.
            • rocklaurence
              • Jan 14, 2009
              • 1841
              aa
              Not hard at all. Take a picture to a fab shop and they could set you up for [likely] $100 or less.
              • SOLSAKS
                • Jul 25, 2016
                • 1781
                10-4 thanx
                80 limited is getting some for me.
                if it fails
                your ideas are good ones.
                dave in NC
                • threepiece
                  • Sep 17, 2005
                  • 1433
                  Perhaps he has a "winch" that lifts the "wench" up high where she would be out of danger. Still that's no way to treat a woman even if she is a "wench"
                  Resistance is not futile yet.
                  • SOLSAKS
                    • Jul 25, 2016
                    • 1781
                    just saw this !!!
                    I got a dang good belly laugh !!!
                    out loud !!!
                    at my own ignorance too,.....
                    thanx for the good laugh
                    even it if was a thinly disguised shot , ha ha ha,,,,...its all good..
                    dave in nc
                    • threepiece
                      • Sep 17, 2005
                      • 1433
                      Originally posted by SOLSAKS
                      just saw this !!!
                      out loud !!!
                      dave in nc
                      I can't hardly blame you. You surly heard or read others use it wrongly. It's a surprisingly common mistake.
                      I got a deal on the PTO winch set-up for my J20 because of this. The seller described it as a wench and the add didn't get the exposure it deserved.
                      After repeated corrections for the last twenty years my friend still calls a winch a wench.
                      • SOLSAKS
                        • Jul 25, 2016
                        • 1781
                        another laugh.
                        thanx
                        sometimes the help I get here is not just for jeeps...
                        sometimes it is mental therapy in the form of a laugh.
                        I will surely spell something else wrong real soon.
                        dave in NC
                        • rang-a-stang
                          • Oct 31, 2016
                          • 5512
                          When I swapped the chassis under my Cherokee (79) I cut the bumper brackets off and welded them to the front of the chassis (78). All those brackets are is C-Channel with some holes in it. I wouldn't bother buying donor brackets because they would be so easy for you to make. If you have a welder, drill and something to cut metal with (grinder, jigsaw, etc) you could make these in less than 30 minutes.
                          These are my 79 brackets welded to my 78 frame. The only holes "needed" and the 3 outer ones. I am not sure what the one on the bottom or the one in the middle are there for.
                          Chuck McTruck 71 J4000
                          (Chuck McTruck Build Thread)
                          00 Baby Cherokee
                          • SOLSAKS
                            • Jul 25, 2016
                            • 1781
                            I agree rang
                            if the cut off pieces I am getting
                            have too much corrosion
                            or if I dont/can't use for any other reason
                            the C channel is a good idea
                            thanx
                            dave
