Old 08-16-2018, 01:28 AM
FSJunkie's Avatar
FSJunkie FSJunkie is offline
Air Cleaner Vacuum Motor
The vacuum motor diaphragm for the innermost trap door inside my air cleaner snorkel has failed. I have been unable to locate a new one from the typical parts sources, including:
BJ's Offroad
Team Grand Wagoneer
Kennedy American AMC Parts
Galvin's AMC-Rambler Parts
Napa/O'Reilly/Autozone
I have the door wired open and the vacuum line plugged for now, but I'd rather have it working as designed because I like my cars "prissy", as this forum calls it.
I just thought I'd ask here to se if anybody here knows a source of new vacuum motors or if anybody wants to sell their used one to me. Lots of folks chuck the stock air cleaners into the trash so if someone wants to pull the vacuum motor off and mail it to me before they trash it...that would be appriciated.
Old 08-16-2018, 08:33 AM
I just sold a pair to someone else. I have one from a 6cyl air cleaner somewhere.
Should also have another v8 pair out in garage somewhere as well.
Got a pic of the linkage? I can dig around and see if it’d work for you.
Or you could probably reuse your likage, doesn’t look likeit would be hard to swap them.
Old 08-16-2018, 03:32 PM
I have an air cleaner base from a 78 I am going to cut up. Do you want just the motor? I would also be willing to cut off almost the whole snorkel and send it. You can have it for shipping.... (only disclaimer, I am writing this at work and have not tested the motor so I may get home and find it's bad).
Old 08-16-2018, 06:59 PM
Kaiserjeeps's Avatar
I needed one a few weeks back for my 70 build. I could not find them anywhere. Then by accident I found them on ebay. There are dozens of choices. I ordered 2 and threw them on the shelf. Take a look there are many.
Am I done yet?
1969 1414X Wag,
1970 and 71 project J trucks
1970 Wagoneer Not Sadie
1953 Willy's wagon
1983 FJ60 wagon
Old 08-17-2018, 03:20 AM
FSJunkie's Avatar
Thanks all of you. I will post a picture of the vacuum motor tomorrow so you can see what it looks like and we can make sure I get the right one.
I figured a lot of you would have these sitting around collecting dust.
This is for my Eagle's 258, but the air cleaner components are the same as the Jeep 258 and 360.
Old 08-17-2018, 08:20 AM
The 6cyl one I should have is from a ‘79 w/ 258.
Old 08-17-2018, 12:51 PM
Tripwire's Avatar
Tripwire Tripwire is offline
the motor easily removes - just one rivet holding it on
Abort? Retry? Ignore? >
86 GrandWag. Howell fuel Injected 360. MSD Ignition + Dizzy. 727/228 BJ's 2" Lift and 31's
Durango rear wiper motor install acct21 Electrical 3 07-26-2017 12:09 PM
Vacuum question(s) Flashfoto General FSJ Tech 17 12-13-2012 05:51 PM
89 GW: clicking sound on acceleration .. 28k General FSJ Tech 46 01-07-2011 02:48 PM
Stock Air cleaner vacuum motor question... UtilityRob General FSJ Tech 3 10-15-2005 02:38 PM
Lots of Oil in Air Cleaner - Thoughts? will e General FSJ Tech 15 11-26-2002 04:26 AM
