First off, Flint, go to the bathroom, grab a cup of coffee and get settled in so we can begin.
OK. Now that we're all here...
After doing several hours of reading about the good ol' QT, I'm worried that what I once thought (hoped) to just be a bad front driveshaft cardan joint, and then thought (hoped) to be a stretched chain, may actually be the 10 spline shaft wearing. My symptom of something being wrong is some fairly scary clunking on most anything other than the mildest of accelerations. I haven't drained the QT to check the chain yet since I don't have any new fluid to put in. I shopped around for the chain and it looks like BJ's has the best deal on one, and since the part time kit needs a new one anyway, I'm going to go ahead and order that (the chain) for sure. However, I am also considering using the part time kit. For anyone that has used (and installed) one, what can you tell me about it? Is there a noticeable mileage gain? Any other advantages? This is all in a 73 Wag that will be 98% street use too, just fyi. Can the part time kit be installed without removing the whole t-case, as the chain can, or does it need to be pulled from the vehicle?
Also of note in this Jeep is that the E-drive switch is completely absent from the truck (as is the actual glovebox, of course).
Thanks in advance!
Thanks in advance!
