OK 1 Year later ..Put heads on today . T RUSTY rUSTY getting a totally rebuilt engine .1990 GW all stock AC and Moon Roof . Rear Wiper . And tons of rot...Rare overhead console with moon roof . keyless entry .outside temp. compass. Best beater I ever had ..
Rebuilds Take Time
Rebuilds Take Time
Last edited by fsj454; 01-07-2019, 07:06 AM.1982 cherokee nt. 454. nv4500 .205. dana 60 f+r. twin stick.hydroboost.hydrolic clutch.rock ram.traction bar.warn 12000 winch.4 wheel disc.flip kit.soa.high steer.cross over steer.4.56 detroit locker.35 spline rear alloy axles. 37s .1990 grand wagoneer aka trusty rustyTags: None
Overhead console with a moon roof??? I got to see this. Other than that mines got the same shizzle... Except mines running and driving...daily.
get-'er-done bud!1990 Jeep Grand Wagoneer-"Big Jeep"
...in pieces for more rust repair...
Originally posted by fsj454Rebuilds Take Time
Then again, nothing feels quite the same as firing up an engine YOU built. Puttin' heads on=getting close!Chuck McTruck 71 J4000
(Chuck McTruck Build Thread)
00 Baby Cherokee
1 3/16 socket
I used a 1- 3/16 socket on my rebuild today . Guess what for ..... This is a time saving tip . Perfect results . Guess what I used it for .1982 cherokee nt. 454. nv4500 .205. dana 60 f+r. twin stick.hydroboost.hydrolic clutch.rock ram.traction bar.warn 12000 winch.4 wheel disc.flip kit.soa.high steer.cross over steer.4.56 detroit locker.35 spline rear alloy axles. 37s .1990 grand wagoneer aka trusty rusty
freeze plugs
OK no nibbles . So I used the 1 3/16 socket to put over brass freeze plugs for painting block . Perfect fit Today I will put a transmission front pump seal in was not leaking but real easy to do now than later...1982 cherokee nt. 454. nv4500 .205. dana 60 f+r. twin stick.hydroboost.hydrolic clutch.rock ram.traction bar.warn 12000 winch.4 wheel disc.flip kit.soa.high steer.cross over steer.4.56 detroit locker.35 spline rear alloy axles. 37s .1990 grand wagoneer aka trusty rusty
That's awesome! (freeze plugs)
I did that seal a few weeks ago, too. Good times!Chuck McTruck 71 J4000
00 Baby Cherokee
Man, this reminds me that I need new freeze plugs, but I don't think I can do them with the engine in. Space looks too tight. That's where im loosing the most of my coolant1990 Jeep Grand Wagoneer-"Big Jeep"
Seals in
Took 10 minutes to remove and install transmission front pump seal . All looked REAL GOOD FOR 102000 MILES . I used a speedy sleeve on balancer because of groove . MSD Distributor gear only comes with 1 hole drilled . WHY. Edelbrock water pump fit with no trimming .The only thing I do not like are those cheap fuel pumps. I glass bedded timing cover and left natural no paint . SOON1982 cherokee nt. 454. nv4500 .205. dana 60 f+r. twin stick.hydroboost.hydrolic clutch.rock ram.traction bar.warn 12000 winch.4 wheel disc.flip kit.soa.high steer.cross over steer.4.56 detroit locker.35 spline rear alloy axles. 37s .1990 grand wagoneer aka trusty rusty
